[SOLVED] How to sync the RGB front panel lighting strip on the Lian LI O11 XL ROG Case with ICUE/Aura ?
bhalton99
71
I finished my new 5th gaming build and I have everything setup to my liking but I can not figure out how to get the Lighting Strip on the Lian Li case off static. The adapter looks like a 4-pin but its actually a 3-pin and both Lighting Strip connections on the Asus Strix X570-E are 4-pins. Any suggestions?
D
4 pin headers are not adressable. You can get a rgb hub that connects via internal usb headers however they are a bit expensive
Hmmm, ok now I'm regretting that I sold the Nodes that came with my LL120 RGB fans. I used the Commander Pro with 2 HUBS to control all 9 fans but I do have 3 ports left on one of the HUBS or maybe I can use the USB header on the Commander Pro itself.
