Yep, its fake and slow.Looks good, physical and data size nice. Transfer rate is horrible at 15mb/s Started adding files and after two days of intermediately adding files, I found that most of the files wound up disappearing
this is not a real 16tb ssd... it only contains 48gb and istead of being an ssd kind... its just an unbranded micro sd card mounted on a pcboard
In addition to the above the real 16TB external drives are based on 2.5 inch ssds so nothing that small could approach that capacity. They would need to squeeze 16 1TB microSD cards into an enclosure along with supporting electronics to create a smaller 16TB drive.
The company has now put the prices of its 50TB and 100TB models (either SATA/SAS) online, with the 50TB edition (EDDCT020/EDDCS050) costing $12,500 ($250 per TB) while the 100TB version (EDDCT100/EDDCS100) retailing for $40,000 ($400 per TB).
In comparison, Samsung’s 30.72TB monster, the MZILT30THMLA, retails for $8,860 ($288 per TB)
Price is double this one - https://www.zdnet.com/article/i-bought-a-16tb-external-m-2-ssd-for-20-and-got-what-i-deserved/
Its not the speed, but rather the capacity.if they never used a fast USB drive before, they may not know they missing out.
That's the one. It's supposed to arrive on the 30th of this month.
Indeed. I tried to cancel the order but didn't see a reply from the vendor in time to prevent it being shipped. So, I decided to test it after getting it and informing Walmart of the results. They really shouldn't be offering items like this that are obviously fake.Once should be highly suspicious when someone is claiming to sell hundred-dollar bills for one dollar.
Will do. Any free programs that do this? They want $107.10 to buy the full version.Can you post a link to the product for us all to enjoy the scam?
Even so, I can give a 99% guarantee its fake.
You can read over the methods here: https://www.passmark.com/support/bit_fake_USB_detection.php#:~:text=Step 1,and / or on the box.
Keep us updated.
Thanks. I'll try looking inside when it arrives. If it contains an SD card, etc. that will save me some time. I appreciate the link to the other tools.Here are some more links:
That said, the trial version will probably fill up the drive way before its "rated" capacity.![]()
WhatSoftware Blog
WhatSoftware, a daily updated Tech Blog with basic and advanced, unbiased software reviews, computer tips news and more!www.raymond.cc
Alternatively, just pop open the plastic enclosure, there is like a USB or MicroSD card inside you can physically identify.
Walmart, Amazon, Newegg....they all have this problem.Indeed. I tried to cancel the order but didn't see a reply from the vendor in time to prevent it being shipped. So, I decided to test it after getting it and informing Walmart of the results. They really shouldn't be offering items like this that are obviously fake.
And don't forget about Amazon. They have an abundance of totally fake stuff. I've sent them complaints but all they seem to care about is the money.Walmart, Amazon, Newegg....they all have this problem.
It is the 3rd party sellers that are doing it, just using their space as the place to sell.
Not much different than fleabay.
Yes, I mentioned Amazon....😈And don't forget about Amazon. They have an abundance of totally fake stuff. I've sent them complaints but all they seem to care about is the money.
I wish there was a way to educate them.
