[SOLVED] How to turn off "load/unload cycle count" for Toshiba MQ04ABD200 ?
Oct 7, 2020
I tried to use the CrystalDisk but it didn't help. The HDDScan didn't help too.
Notebook: HP ZBook 17 G6
Thanks
Maybe you could schedule a tiny background task to run just before the idle timer expires. For example, you could configure a SMART tool to check the SMART report at 1 minute intervals.
That helped, thanks.
I used CrystalDisk
Function > Auto Refresh - set 1 min
Function > Auto Refresh Target - select required HDD
TOSHIBA support replied that the "load/unload cycle count" parameter cannot be turned off for this HDD
