Hi
I'm a bit noob at PC stuff so I tried to follow a guide for a clean windows 7 install.
It was going ok till' I started the shift+F10 step, to open a command prompt windows.
I did:
1. dispart [enter]
2. list disk [enter]
3. select disk 0 [enter]
4. clean
- Now I know I should have stopped at number 4. command because that's what I only needed, to clean the disk but i continued as shown in the site due my ignorance on the topic.
5. create partition primary align=1024 [enter]
6. format quick fs=ntfs [enter]
7. assign [enter]
8. active [enter]
9. exit [enter]
10. exit [enter]
Now I only have one local disk (C: ) with 931 GB (1T I think) instead of two local disks, (C: ) and (D: ) which I don't remember how many GB had each one, and I also believe there was a hidden 100 MB partition.
My question is: How can i undo this mess i did? Should i create the (D: ) partition and also the hidden 100MB one? If so, how do I distribute the GB in each (C: ) and (D: ) local disks, knowing that my PC is more dedicated for gaming (if that matters)?
Thank you in advance,
Miguel
I did:
1. dispart [enter]
4. clean
7. assign [enter]
8. active [enter]
9. exit [enter]
10. exit [enter]
Miguel
