How to use CPUID HWMonitor, CPU temps
JimBobWales
84
So I'm trying to use CPUID HWMonitor and I see three different temperature readings for my cpu (FX 8320)
2 of em are under the motherboard dropdown and it reads;
Temperatures
-CPU
-Mainboard
The last one is under the CPU dropdown and it reads;
Temperatures
-Package
Which of the three should I look at when trying to overclock or put the system under heavy load?
Screenshot of CPUID HWMonitor;
http://imgur.com/6qFPZmn
Package is the temperature on the CPU die, consider core temps around 5C higher at all times. I'm guessing the "CPU" temp from the motherboard is the socket temperature, which you should just ignore.
are you sure your on the latest version of HWMonitor? you should see each cores temperature. but look at the cpu(thats just above mainboard) that says 32 degrees, thats the one to look at
yeah its the latest version of CPUID HWMonitor. So what are the package and mainboard temperatures?
im not sure what the package is, i believe mainboard is the motherboard
