How to use Creative inspire 5.1 5200 as a monitor for an audio interface
Hi,
I have a line 6 UX1audio interface. Is there a way to connect my creative inspire 5.1 5200 to it so that I can use it as a monitor for the audio interface?
You should be able to connect them to the line level outputs.
Since the speakers are only have 5.1 inputs you can only get 2.0
You might be able to use them as monitors which leaving them connected to the PC. Check with Line 6 or the manual.
