Hi! My question is simple: How can / will I mount a radiator to this? It says that it can fit upto 360mm radiators but Idk how haha.
Img link: https://ibb.co/8d3237H
[Matrexx 70 3f]
[Matrexx 70 3f]
Tysm!https://www.deepcool.com/download/pdf/MATREXX_70.pdf
Looks like you have to take off the front panel (labeled I) and mount the radiator to the radiator holder (labeled J).
Im working on a custom solution 😀Glass front will really hurt the performance.
