Question HP 27XW monitor Split Screen
rgh43
58
With the above Monitor I can go from one PC to another as it has a Dual HDMI feed. Now my? is, can I see both PC's at the same time with a split screen? The PC's are both the same Brand & Model and I want to see exactly what is in the C & D Drives as the 2nd one belongs to my Great Grandson and he is having some issues with the PC. If I can split the screen looking at both PC's @ the same time it will be much easier. If not I will have to switch back and forth to do what I want to do, it would just be easier to view both at the same time, .
It is simple to go back & forth just hit the button on the bottom of the monitor.
Thank for any help on this question.
rgh43
rgh43
That feature is usually available only with ultra wide monitors.
