HP Envy h8-1414 Upgrade to 4k - Desktop - AMD - Need advice to upgrade graphics and power supply.
aking83
9
HI,
I use a HP ENVY h8-1414 Desktop PC for my work pc, purchased back in 9/2012.
I want to upgrade to a 4k display and also use my 1920x1080 samsung display.
I have a Dell 27" 4K Monitor.
The computer Specs:
CPU: AMD Fx 6120 Six Core - 3.50 GHZ 10 gig ram with Windows 8.1 64 bit
Motherboard: Gigabyte - M3970AM-HP
Graphics - AMD Radeon HD 7450
Power Supply - 300W (100v-240v) - Internal ATX
What would you recommend for a good video card and upgraded power supply, instead of getting a new PC.
Thank you for your time,
Anthony
Plain and simple, the CPU here is not powerful enough to support the GPU(s) you need for 4k gaming.
You cannot upgrade this computer to successfully play at 4k.
Sorry.
IF you only want to use a 4k display, but not play any games at all, that may be possible.
Sorry.
I'll look into those, thank you. The image editing i'm talking about is resizing, and light touch up, nothing fancy.
90% of the time using outlook, excel and web browser.
