HP P6-2310 PC upgrade, will it work and/or fit?
AG x V3N0MZz
Commendable
Dec 28, 2016
4
I am new to building or upgrading PC's so I Need some help before doing absolutely anything to mine. Anyways, this is the PC I have:
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c03513433-14
and this is what I want to upgrade it with:
CPU - http://www.currys.co.uk/gbuk/computing-accessories/components-upgrades/processors/amd-a10-7860k-fm2-black-edition-apu-retail-10146851-pdt.html
GPU - http://www.currys.co.uk/gbuk/computing-accessories/components-upgrades/graphics-cards/pny-geforce-gtx-1050-ti-graphics-card-10157450-pdt.html
Now this is what I'm currently worrying about: some places/people have said that this sort of PC probably won't fit the GPU (I'm looking for) inside the case or PCle slot and also the GPU says it supports 300w and the power supply I have runs 300w so will that work once I have installed it or will I need to upgrade the PSU aswell? I'll be able to post some pictures of the inside of my PC case soon
MERGED QUESTION
Question from AG x V3N0MZz : "Will these upgrades work/fit in my PC? (FULL EDIT)"
MERGED QUESTION
Question from AG x V3N0MZz : "HP P6-2310 PC upgrade, will it work and/or fit?"
MERGED QUESTION
For the CPU:
The socket is different and won't work on that motherboard. Consider getting a more recent one
For the GPU:
It should physically fit in the case and PCIe slot. However knowing the parts in prebuilt PCs I'd search for a new PSU.
That's all I can tell you sadly. I don't know much about AMD systems.
