HP Pavillion 414uk Problem with CDRW
G
Guest
Guest
Archived from groups: comp.sys.hp.hardware (More info?)
Since yesterday my hp pavilion does not recognise my cdrw. I have tried
looking in device manager and all i get is a yellow circle with a black
exclimation mark against my drive which is a cyberDrv CW088D. I have made
enquiries in another group and have been told that I need to replace my
drive. Can someone more knowledgeable than me please tell me if this is the
case? I should point out that when I look in properties the device status
window displays the following error message:-
Windows successfully loaded the device driver for this hardware but cannot
find the hardware device. (Code 41)
TIA for any help you can give me
Check the cable and power connections, and examine the motherboard BIOS CMOS
setup information. The CD-RW should show up in the BIOS setup.
.... Ben Myers
On Tue, 14 Sep 2004 14:33:51 GMT, General Martok <Martok@theklingonempire.net>
> CMOS setup information. The CD-RW should show up in the BIOS setup.
> ... Ben Myers
>>made enquiries in another group and have been told that I need to
>>replace my drive. Can someone more knowledgeable than me please tell me
>>if this is the case? I should point out that when I look in properties
>>the device status window displays the following error message:-
>>cannot find the hardware device. (Code 41)
The problem has now been fixed. It was a problem in the registry.
On Wed, 15 Sep 2004 10:28:14 GMT, General Martok <Martok@theklingonempire.net>
wrote:
<SNIP>
Unfortunately, a very common occurance with Windows. The Windows registry has
an extremely weak design, prone to errors caused by software manipulating
registry entries incorrectly... Ben Myers
