hp pro 3500 case upgrade
hasd15568
108
Hi
i want to upgrade hp pro 3500 mt case
so what case should i choose :
antec gx200 mid-tower
or cougar mx330 mid-tower
and this mobo fit or not ??
The motherboard will fit into any case that supports MATX motherboards and the IO shield is removeable. The USB 3.0 connectors are not compatible with the board so you will not be able to use those but any USB 2 headers can be connected fine.
I moved my cupertino2-H61 motherboard into a coolermaster masterbox 5 lite and it fit in just fine and I've had no problems so far.
so i cant use pc cases front panel on new case ??
