hello im using hp victus 16 right now, and the cpu that I use is ryzen 7 7840hs
the problem is my cpu never goes above 3.2 ghz even if im gaming
i tried multiple things like changing my power plan and selecting full performance settings on omen gaming hub but nothing works
and also my clock speed sometimes goes to 4.8 ghz for a sec then goes below 3.2 ghz again
I have no issues of over heating because its always 60-65 degrees when im gaming (both cpu and gpu)
I can play most of the recent games but I do not get a stable fps its always like 100 to 130 changing every second
and also because of the cpu clock speed it does not matter if i play the game on high settings or low settings I always get the same fps
is there anyway to fix this issue ?
I tried to use UXTU but it did not work neither because I dont know which settings to change or to do
