HP XW8000 dual 2.4 Xeons - U1 power supply solutions - Ple..
G
Guest
Guest
Archived from groups: comp.hardware,comp.sys.hp.hardware,comp.sys.ibm.pc.hardware,comp.sys.ibm.pc-hardware (More info?)
Hello,
I was wondering if anyone could please help me out in this problem my cousin
and I are having. we have a HP xw8000 motherboard, but we put this board
into a U1 rack chassis.. the original HP power supply that came with this
board does work but the U1 power supply we bought for this board.. 1U
EPS Sparkle FSP460-601U.. well it did not work..after hooking it up, turned
it on and got nothing but an error beep that the HP manual describes as:
"Power supply is in protected mode, or system is hung in an undetermined
on/off state."
http://h200005.www2.hp.com/bc/docs/support/SupportManual/lpv38919/lpv38919.pdf
Power supply info: http://thcclan.kicks-ass.net/files/voltages.xls
I need to know what power supply will work with this system board.. must be
a U1 power supply to fit in the chassis. or is this a motherboard
grounding issue.
PS.. My cousin has more INFO about this issue with other responses at this
website Forums:
http://www.lanwar.com/forumsh/forum/topic.asp?TOPIC_ID=11854
any help will be appreciated GREATLY.
Please email at grimzella@comcast.net
thank you
Dave
Try the mobo outside 1U with RAM/Graphic/Floppy and PSU. I use a ground pad
but a wood table would do. Let me know, as I did not have time to check spec
on mobo/PSU. Some boards from tier-1 company has proprietary requirements.
"Grimzella" <grimzella@comcast.net> wrote in message
news😀Kajc.41772$_L6.2533725@attbi_s53...
> Hello,
cousin
board
turned
> on/off state."
be
> grounding issue.
> website Forums:
> thank you
> Dave
