Hi - my first post here after months of tech support lurking!
I'm trying to strip a HP Z400 down to just PSU, Motherboard, Hard Drive.
I've sorted the errors caused by removing Firewire '913-Front 1394 Not Connected' and Audio '917-Front Audio Not Connected' through BIOS changes and USB '918-Front USB Not Connected' through a hardware jumper pin - but the '513-Rear Chassis fan not detected' error I'm getting when I remove that part has me stumped.
I've seen people post about connecting the 'sense' pin of the CPU fan connector to the same pin on the rear chassis fan connector and it looks like that would be pin 3 (green wire) on both the 5 pin CPU fan and the 4 pin chassis fan connectors.
There's posts here and here related to this and on my machine both those cables have what I believe is 1: GND (Black) 2: +12V (Yellow) 3: Sense/RPM Feedback (Green) 4: PWM Control (Blue) (with the 5 pin connector doubling up on the GND for the CPU fan).
Before I start hacking into molex connectors - is there anyone here that can offer any advice on whether the solutions listed above work or if there's any other way of dealing with this?
Just to be clear - I'm looking to completely remove the rear chassis fan - not replace it.
Thanks!
Thanks!
