I have a HP Z400 with the following specs:
CPU: Intel Xeon X5550 2.67 GHz
Motherboard: Hewlett-Peckard 0B4Ch
RAM: 8 GB RAM DDR3 @ 533MHz (dual channel)
GPU: Nvidia GeForce GTX 750 Ti Windforce Gigabyte 2 GB VRAM
Power Supply: Stock HP Z400 Power Supply 475W
Now a little bit of background. A few days ago there was an explosion in my area probably related to electricity as there was also a power outage. My PC was on and due to the outage it shut down. There was burning smell afterwards and probably a spark or two I saw.
After electricity was restored my PC was no longer booting up. The power supply seemed dead as the motherboard light wasn’t on either. I bought a used (probably refurbished) HP Z400 power supply with the same power rating as the old one. It worked well for one whole day. The next day I tried booting up my PC I was met with the red light blinking 4 times with a beep each time. Official HP site states it is a power failure issue. The motherboard light is on when I plug in the PC and if I press the power button the CPU Fan and GPU fan turn on briefly for a second before they stop and the red light appears on the power button beeping/blinking 4 times.
Yesterday while fiddling around the PSU wires (mainly P1 24-pin connector) to the motherboard my PC finally booted up. I turned it off and after trying to turn it back up was met with the same red light issue.
Things I have tried so far:
Unplugging all devices
Unplugging all PSU connectors except to the motherboard
Fiddling around the wires.
Is the PSU completely dead or just has a faulty/loose connection to the motherboard? Do I have to get it replaced?
