[SOLVED] Hp z440 mod no power
Feb 6, 2020
6
Have a progect that I don't know what to do with
I traded for a i7-6800k not realizing I needed a x99 Chipset so went on line and found a few blogs were they used a hp z440 motherboard even though it has a c612 chip set so I ordered it didn't realize it had a proprietary psu hook up but with so research and so passionce I moded my 1300 watt psu 20 pin motherboard connector to the motherboards 18 pin according to the diagrams I found and on the side in the 12 pin CPU memory power connector I placed an 8 pin and a 4 pin cpu connections put in my memory non ecc memory into slots 2 4 5 7 installed the cpu and my Vega 64 gpu and tried to boot but no sign of power double check the 18 pin connector with the multi meter and its correct
Please help why wont I power up
