I am desperatly trying to access the LAN of a phenoix Mgaurd router using a web browser because I need to change its WAN address from 172.16.2.49 to 192.168.1.4 ;
To access the MGaurd setting you have to use the address 10.208.0.25 .
OBviusly using a standard laptop the above address is "out of range" for the laptop to communicate there I have to in "internet settings" enter manually the protocol IP address to something like;
IP: 10.208.0.29
Subnet mask: 255.255.255.240
This then allows me to PING and get a REPLY from 10.208.0.25.
I am now ready to open up a web browser and type in the address bar: https://10.208.0.25 but nothing loads up. I am 100% certain it is trying to do something with that address but something is blocking it.
The reason I am sure it is trying to connect is by looking at the green load up bar at the bottom of the page. If I type in address's that don't exist in the net work and then compare that to how the bar trys to load up with 10.208.0.25
The firewall is off. Proxy box is unchecked. No one thus far has been able to help me in the real world therefore I joined this forum to get your guys help. Thank you.
IP: 10.208.0.29
