Hello,
I was wondering if anyone had any experience using a wearable smart watch or fitness band to get notifications from a ring doorbell ?
As you may have guessed from my title I am looking at getting a simple tracker in the form of the huawei Band 4 Pro, it states that it will show notifications but there are no real details.
Online I have read that some smart watches and bands have limited compatibility while others will send most app notifications.
I am also wondering if the notification would be sent in real time. obviously sending a notification that someone is at my door when it was in fact 2 minutes ago is a bit pointless.
I am not totally set on getting the band 4 pro , it just seems the best option considering I have the P30 pro right now.
I don't really see the ability to connect to ring or not as a deal breaker, its a quality of life nice to have feature.
I just like to try and do my homework before buying.
Any and all other options/advice or recommendations welcome.
Thanks for reading
Mactronix
Thanks for reading
Mactronix
