[SOLVED] huawei lte cpe b593 after unlocked not working 4G LTE
Skyakimax
73
i unlocked my 4g wifi router ,,after unlocked router not working 4G LTE mode only work 3g why? i inserted Both FDD/ TDD sim both work only 3g how i can fix
There are actually a couple more models than this but this is one list I found.
You will see it support only band 38 and 40 using TDD.
Huawei B593 4G LTE CPE Industrial Wireless WiFi Router Speci:
Frequence:
HUAWEI B593u-12: LTE FDD Band 1/3/7/8/20 (800/900/1800/2100/2600MHz) without telephone port
HUAWEI B593s-22: LTE FDD Band 1/3/7/8/20 (800/900/1800/2100/2600MHz) and TDD Band 38 (2600MHz), LTE Category 4 CPE (Speed up to 150Mbps)
HUAWEI B593u-91: LTE TDD Band 38/40 (2300/2600MHz)
3G: HSUPA / HSDPA / UMTS / DC-HSPA+ 900/2100 MHz
2G: EDGE/GPRS/GSM 850/900/1800/1900 MHz
I will assume you...
reset the router, update the firmware if available
https://forum.huawei.com/enterprise...ion-and-firmware-upgrade/thread/457437-100305
The coverage might not be good enough for 4G where the router is placed. Try a different place.
Is only a green LED on and not a blue one?
there have good 4g coverage,, i am using broadband connection 4G it router work 4g, its Locked one, problem has my other unlocked router it not catch 4G only 3G can catch model no is B593u-91 huawei
only light green led, not blue one, i tried everything not work 4G tried both format Sim cards TDD and FDD not work
Are you using it on the same exact provider or did you attempt to move it to a different provider.
Like most LTE devices just unlocking them does not mean they work on all vendors. They must function on the correct radio channels. Do you know which band the ISP you are trying to connect to runs on.
From a quick search on that part number there are actually 5 sub models. There should be a letter and numbers after the main router number. This represent the radio bands it will function on.
i am trying different IPS providers, today I changed router connect mood, I changed connected mood as Manual manual Search it Worked TDD 4G,, but mobile FDD sim not working 4G
my router model is
huawei b593u-91 you mean this one?
Frequence:
I will assume you live in europe because these bands are not used many other places. You can look through this table and see the ISP and countries that support these bands.
https://en.wikipedia.org/wiki/List_of_LTE_networks_in_Europe
Frequence:
thanks,, do you know unlock routers? using linux?
Unlock is about which ISP you can connect it to not what radio band it runs on. If 2 different ISP use the same radio bands you can activate it on either. A locked router would only let you run a single ISP even if others used the same radio bands.
You can not change the radio bands it functions on. That is why there are different model numbers. This is something that is set at the factory when the device is manufactured.
This is sorta like CDMA vs GSM phones in the USA. You can unlock say a verison phone but since it uses CDMA for voice you can not make it function on ATT who uses GSM
thankx
