Huge difference in CPU temp reporting between MBM5 and Asu..
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have a new A8V Deluxe with A64 3500+ running stock speeds/fan/hs.
Nothing fancy. For the heck of it I ran MBM5. I chose the only Asus A8V
mobo from the list, the Deluxe Wireless Edition. I don't have the wireless
feature but I assumed it was all the same sensors.
MBM5 reports my CPU temp as between 18 and 24C depending on what I am
doing. That seemed ridiculously low so I became suspicious. MBM5 uses
winbond 1 for CPU temp. Whatever the heck that means.
Anyway, I installed Asus' PC Probe to compare. It reports the CPU temp
between 40 and 50 depending on what I am doing. HUGE difference. I don't
know what sensor Asus PC Probe uses but I'm sure it's the RIGHT one. I
started farting around with MBM5's settings and found that if I told it to
use winbond 2 for the CPU temp it matched exactly with Asus PC Probe.
So, unless someone knows something I don't know, don't rely on MBM5 with
the Asus A8V. I think it's wrong.
"Jack White" <jackwhite@ncrr.com> wrote in message
news:6hur11th032egli4fnlpag4e197kq36bhh@4ax.com...
I don't have MBM5 installed, but can you configure it for the A8V's sensors?
If you cannot, try SpeedFan, which (in its latest version) auto-configured
itself to read my A8V's sensors correctly.
Winbond 1 is the case sensor, and Winbond 2 is for the CPU. My A8V with A64
3500 winchester runs 25C for the case, and 38 degrees C or so for the CPU
Bob
"Peter van der Goes" <p_vandergoes@toadstool.u> wrote in message
news:AzFTd.2791$Hs.2763@okepread04...
>> wireless
>> to
> sensors? If you cannot, try SpeedFan, which (in its latest version)
> auto-configured itself to read my A8V's sensors correctly.
