Huge Frame Drops
fallindivine
EVGA Z270 Stinger, LGA 1151, Intel Z270, HDMI, SATA 6Gb/s, USB 3.1, USB 3.0, mITX, Intel Motherboards 111-KS-E272-KR
ASUS GeForce GTX 1060 3GB Dual-Fan OC Edition Graphics Card
Intel Core i7 6700K 4.00 GHz Unlocked Quad Core Skylake Desktop Processor
G.SKILL TridentZ RGB Series 16GB (2 x 8GB) 288-Pin DDR4 3000MHz
EVGA SuperNOVA 850 P2, 80+ PLATINUM 850W
I'm getting frame drops on some of the easier games to run even at lowest quality. On League of Legends alone I go from 250+ FPS to 10. PUBG gets very stuttery. The list goes on. I use MSI AfterBurner to check temps of graphic card and is in far in threshold of temp. Processors not getting hot. All drivers are up to date. I'm 100% at a loss at this point. Any Ideas?
Also, run this test:
http://www.speedtest.net/
To make sure your internet is running at the proper speeds. Run it several times to see if there are big fluctuations in the speed. Compare what you're getting to what you're paying for.
Which windows are you using. Try reinstalling the windows . Update bios to the latest version,(reinstall bios if already up to date.These are the things you should at least try.
