Huge performance problem with my computer, please help me Urgent!
Jun 1, 2018
18
Motherboard Name ASRock FM2A55M-VG3
CPU Name AMD A6-6400K APU with Radeon(tm) HD Graphics 3.9GHZ (Turbo core enabled thats 4.1 ghz, that 2 core proccessor) (i use artic cooler mx4 thermal compound)
Memory: Corsair Vengeance CMZ8GX3M2A1866C9 1866mhz 2x4gb(enabled xmp the motherboard wrie memory speed 1333mhz and enabled xmp(1866mhz) when i am playing gpu-z write in the memory that 833mhz)
Video Card: PCI Express 2.0 x16: MSI N660 (MS-V287)
Hard Disk1 (This is system hard disk): WDC WD5000AAKX-00ERMA0
Hard Disk2: Hitachi HTS545025B9SA00(Thats my family videos or pics no really use)
PSU:EVGA GQ 750W (i bought 2 days ago thats new )
Windows 10 Pro Version 1803 (OS Build 17134.81)
Monitor: samsung 1080p monitor (i use 1920x1080 but when im gaming i tried 1024x768 and lag again) i use it HDMI1.4 cable i tried with DSUB
my integrated graphics card is disabled shows all 8gb memory.
I use the stock cooler for cpu.
Thermal idle:
Motherboard: 27°C
CPU : 28-30°C
GPU Diode 29 °C (84 °F)
WDC WD5000AAKX-00ERMA0 38 °C (100 °F)
Hitachi HTS545025B9SA00 32 °C (90 °F)
when gaming:
(osu)
Motherboard: 40 °C
Cpu:CPU 55-60 °C
Gpu: 50-55 °C
HDD 40°C WDC THATS GAME RUNING THIS HDD
I tried install older version driver for card now the latest driver installed, and i tried install windows 8.1 64bit and lagging games and youtube 60 fps
video. Youtube stats write drop high number frames when i play ( 60 fps 720 p) 60 fps and 1080 60 fps lagging i tried turn of hardware acceleration not fixed.
I was run 10 times Memtest +86 and the first stick (1. memory module )= 12 pass and second stick(2. memory module ) =12 pass , and i tried with 2 stick = 11 pass.
HDDs write hdd sentinel 100-100 not problem .
I updated motherboard bios and the video card bios. Tried with nvflash install older stock bios. And lagging again.
The same games lags 60 fps i tried low setting with 1024x768 and lags . Tried v-sync enable and disable.
I have no idea why lagging games and youtube 60 fps video old times worked very well i tried old version chrome and edge every browser lag 60 fps video.
Please help i tried everything i think hardware problem please help. I'm newbie for this please help. Maybe bad bios setting but i tried reset setting with jumper and lag problem is not fixed.
Sorry for my bad English.
All games dirt 3 low 1024x768, osu lagging, counter strike 1.6 huge frame drope i set maximum 60 fps limit and drops 60 -40 fps. I don't know why but thats the important thing youtube videos 720p 60 fps and 1080p 60 fps is high frame drop. I move my cursor high lag video and i not move starts random lagg only 60 fps video.
look: https://imgur.com/a/3yrOWDx
Long time ago (1 year ) it went perfectly not lag youtube video i have no idea whats happen one day start lag and i tried windows 8.1 install all driver (nvidia) old new update vga and motherboard bios and older vga bios with nvflash. What can I do.
I tried HWMonitor is write not correct information i no use my computer (idle windows) hwinfo write 75C aida and hwinfo write 35 C.
I don't know why. When i play game , aida write 40C and HWInfo 85 C i changed fresh thermal compund.
_Try disabling windows 10 DVR function and DVR Game Bar >> What Are Game DVR and the Game Bar? How to Disable Windows 10’s Game DVR (and Game Bar)
_Try also disabling Geforce experience in-game streaming and recording features and verify game profile running resolution in Nvidia control panel.
_I would also make sure you're gaming on your GTX 660 and not using your APU (Radeon HD 8470D) especially with the high APU usage at task manager (100%), please have screen capture Hwmonitor software in idle and while gaming with CPU / GPU temps, usage, clocks and fan speed, (you can also check with GPUz which graphic card is being used while gaming)
https://imgur.com/a/PHDIY1H
When im playing thats the temperature my system. My processor has a "turbo core" thats default enabled 3.9 up to 4.1 ghz
I looked games is lagg ful screen but windowed run better i don't know why. Of course, i played fullscreen not windowed 1 hour. I pressed alt+tab and run windowed an i captured this screen.
Hi how can i do diasble dvr i tried but i can't i searched settings in windows .
Yes i think my gtx is first card integrated amds is disabled look: https://imgur.com/a/PHDIY1H
I looked games is lagg ful screen but windowed run better i don't know why. I readed full screen optimisation i tried run game van i checked disable full-screen optimisation not good when windowed mode run the game better run.
I not logged in and i not use geforce experiance.
And what can i do for youtube 60 fps videos not lag ? Thanks
