[SOLVED] Huge price difference between two workstations?! Question
Specs look the same, get whatever is the cheaper system as long as you are happy with the maker reputation and warranty. I am guessing that Tyrone system is a local company, the Dell may be easier to service and get warranty help with.
I did with an IP from the US, it doesn't work either.
Do you mind copying and posting the full specs of those PCs here?
It's a LONG list! Here it goes
Tyrone Computer Workstation Camarero DS400TR-54 RS062040621 - 9,179 USD Price
Type
Form FactorDesktop
Processor
Processor MakeIntel
Processor GenerationNA
Number of Cores per Processor16
Processor Base Frequency (GHz)2.3
Processor Turbo Frequency (GHz)3.9
Processor DescriptionIntel Xeon Gold Series
Processor NumberIntel Xeon Gold 5218
Number of sockets available on the motherboard2
Number of Sockets populated with the Processors2
Cache (MB)22
Out of Band ManagementIntel vPro
Motherboard
Chipset NumberIntel C621
Expansion Slots (PCIe x 1) (Number)0
Expansion Slots (PCIe x 4) (Number)0
Expansion Slots (PCIe x 8) (Number)2
Expansion Slots (PCIe x 16) (Number)4
Expansion Slots (PCI) (Number)0
Graphics
Graphics TypeDedicated/Discrete
Number of Graphic Cards1
Graphic Card DescriptionnVIDIA Quadro RTX 4000 8GB
Operating System
Operating System (Factory Pre-Loaded)Ubuntu Linux
Recovery Image MediaNA
OS CertificationWindows,Ubuntu Linux,Redhat Linux
Applications
Applications Compatible with the Workstation (Requisite document may be furnished as and when demanded by the buyer)Adobe After Effects CS/CC,Adobe Photoshop CS/CC,Autodesk AutoCAD,Autodesk Maya,Dassault Systèmes SolidWorks
Memory
RAM TypeDDR4
RAM Speed (MHz)2666
Type of MemoryECC RDIMM
RAM Size (GB)128
Total Numbers of DIMM Slots Available16
Number of DIMM Slots Populated4
RAM Expandability upto using spare DIMM Slots (GB)768
Primary Storage /Boot Drive
Type of Drives used to populate the internal BaysPCle
Number of Drives1
RAID for Operating SystemNA
Capacity of each Drive (GB)512
Secondary Storage
Type of Drives used to populate the Internal BaysSATA
Total number of Internal Bays available for SATA Drive5
Number of Internal Bays populated with SATA Drive1
Each SATA Drive Capacity (GB)2000
Speed of each SATA Drive (RPM)7200
Total SATA Drive Capacity (GB)2000
Total number of Internal Bays available for SAS Drive0
Number of Internal Bays populated with SAS Drive0
Capacity of each SAS Drive (GB)0
Speed of each SAS Drive (RPM)0
Total SAS Drive Capacity (GB)0
Total number of Internal Bays available for SSD0
Number of Internal Bays populated with SSD Drive0
Capacity of each SSD Drive (GB)0
Total SSD Capacity (GB)0
Total number of Internal Bays available for PCIe SSD1
Number of Internal Bays populated with PCIe Drive1
Capacity of each PCIe Drive (GB)512
Total PCIe Drive Capacity (GB)512
Class of PCIe DrivesNA
RAID
RAID level0,1
Number of RAID Controller Ports8
Speed of RAID Controller Ports (Gbps)6
RAID Controller Cache (GB)0
Connectivity
Type of Ethernet PortsDual Gigabit NIC 10/100/1000
Number of Ethernet Ports2
Wireless ConnectivityNo
If Yes, Type of Wireless ConnectivityNA
Bluetooth ConnectivityNo
If Yes, Version of Bluetooth Available0
Ports
Number of USB Version 2 Point 0 Ports0
Number of USB Version 3 point 0 / 3 point 1, Gen 1 Ports4
Number of USB Version 3 point 1, Gen 2 Ports2
Number of USB Type C Ports0
Number of VGA Ports1
Number of HDMI Ports0
Number of Mini DP Ports0
Number of DP Ports3
Display
Display AvailabilityMonitor
Display Size (cm)54 - 56
Display TypeNon Touch
Panel TypeFlat
Panel TechnologyIPS
Display Resolution (Pixels)1920x1080
LED BacklitYes
TCO Compliance for MonitorTCO 07
Colour Gamut72% Color Gamut
Monitor StandStandard
Power
Maximum Power (Watts)1200
Minimum Power Efficiency (%)80
Power Management UnitYes
Redundant Power SupplyNo
Input Devices
Mouse Connectivity, If availableWired
Type of Mouse, If availableOptical Scroll
Keyboard Connectivity, if availableWired
Type of Keyboard, if availableStandard
Type of Keyboard in case of Mobile WorkstationNA
Generic
Optical DriveNA
Number of External Bays3
SecurityS/W Based
Docking Station for Mobile WorkstationNo
Availability of Bundled SoftwareYes
Type of Bundled SoftwareStandard Performance Improvement Software
Finger Print Reader in case of Mobile WorkstationNA
Carry Case in case of Mobile WorkstationNA
Certification
BIS Registration under CRS of Meity (Requisite certificate may be furnished as and when demanded by the buyer)Yes
BIS Registration Number and its ValidityR-91001422
ROHS ComplianceYes
Other Certification Available (Requisite certificate may be furnished as and when demanded by the buyer)UL
Operating Conditions
Minimum Operating Temperature (Degree C)10
Maximum Operating Temperature (DEgree C)70
Minimum Operating Humidity (%RH)35
Maximum Operating Humidity (%RH)95
Warranty
Battery Warranty in case of Mobile Workstation0
On Site OEM Warranty (Year)3
Dell Precision 7820 Tower - 6,815 USD Price
Type
Form FactorDesktop
Processor
Processor MakeIntel
Cache (MB)22
Motherboard
Expansion Slots (PCIe x 1) (Number)1
Expansion Slots (PCIe x 4) (Number)1
Expansion Slots (PCIe x 8) (Number)1
Expansion Slots (PCIe x 16) (Number)2
Expansion Slots (PCI) (Number)1
Graphics
Operating System
OS CertificationUbuntu Linux,Redhat Linux
Applications
Applications Compatible with the Workstation (Requisite document may be furnished as and when demanded by the buyer)Avid Media Composer,Dassault Systèmes SolidWorks,Dassault Systèmes CATIA,PTC Creo,Siemens NX
Memory
RAM TypeDDR4
RAM Speed (MHz)2933
RAM Size (GB)128
Total Numbers of DIMM Slots Available12
Number of DIMM Slots Populated8
Number of Drives1
Secondary Storage
Total number of Internal Bays available for SATA Drive0
Speed of each SATA Drive (RPM)0
Class of PCIe DrivesClass 40
RAID
RAID level0,1,5,1+0
Connectivity
Ports
Number of USB Version 3 point 0 / 3 point 1, Gen 1 Ports8
Number of USB Version 3 point 1, Gen 2 Ports0
Number of USB Type C Ports2
Number of VGA Ports0
Number of DP Ports3
Display
Panel TypeFlat
Panel TechnologyIPS
LED BacklitYes
Monitor StandHeight Adjustable
Power
Maximum Power (Watts)950
Minimum Power Efficiency (%)90
Input Devices
Type of Keyboard, if availableStandard with Rupee Symbol
Generic
Optical DriveDVD R/W
Number of External Bays2
SecurityH/W Based
Type of Bundled SoftwareArtificial Intelligence Based Performance Improvement Software
Certification
BIS Registration Number and its ValidityR-67000094
ROHS ComplianceYes
Other Certification Available (Requisite certificate may be furnished as and when demanded by the buyer)UL,CE,FCC
Maximum Operating Temperature (DEgree C)35
Minimum Operating Humidity (%RH)20
Maximum Operating Humidity (%RH)80
Warranty
