So I just overclocked my FX-6300 to 4.2GHz @ 1.3v (not final, hoping to get it higher), and I did a quick stress test using Prime95 to check out the temps (using HWMonitor), and to make sure it's somewhat stable. When I started the test, I quickly found out that I wasn't sure what to look at for the CPU temperatures, as I have (There is also a picture down below which shows this a bit better) "ASUSTeK COMPUTER INC. M5A99X EVO R2.0 > Temperatures > CPU" which maxed out at 61 degrees Celcius, and I have "AMD FX-6300 > Temperatures > Package" which maxed out at 49 degrees Celcius.
Picture:
I'm sure there are many threads like this, but I couldn't find one with these exact readings, so that's why I'm asking.
So what's the better one to look at, "CPU" or "Package"?
Also I have a Hyper 212 Evo if you're wondering whether or not I have a cooler.
Thanks
Edit: Just noticed that "TMPIN2" (whatever that is) is saying that it's at 128 degrees Celcius... I'm going to guess that HWMonitor is a tad off on that one...
Edit 2: Found a guide to overclocking the FX-6300, where under "Software" and then "Temperature Monitoring" it shows max temps for both "CPU temp" and "Package temps", should I use these as a reference point? (http://www.overclock.net/t/1348623/amd-bulldozer-and-piledriver-overclocking-guide-asus-motherboard)
Picture:
Thanks
