Hybrid Cooler Question for GTX 1080
elisz
48
So I've found a Hybrid cooler for GTX 1080, Question is, I have a GTX 1080 FTW edition and I didn't see the model of the FTW edition on the product info of the Hybrid. (link: http://www.evga.com/Products/Product.aspx?pn=400-HY-5188-B1) I was wondering if anyone had installed this cooler on a GTX 1080 FTW version?
no, you can not use it on FTW card, at least not completely.
FTW are "custom" PCB design which is larger than "reference" PCB.
you might want to take a look at:
https://www.arctic.ac/worldwide_en/accelero-hybrid-iii-140.html#
You will have to improvise a bit with VRM cooling.
the other option is to sell your card and get the EVGA 1080 Hybrid.
If you had a custom loop, I'd suggest a full cover block, but you will have a hard time to find one. EK status for FTW cards is comming soon.
