F Facelessman Commendable Jan 9, 2017 41 0 1,530 Jul 1, 2017 #1 Should I go for the CM Hyper 212 Evo, 212X or the Bequiet pure rock slim? For the i5 6500.
Solution geofelt Jul 1, 2017 I5-6500 will come with an adequate stock cooler. It may get noisy under load though. Of your choices, I would pick the pure rock slim. Apparently the hyper212 is hard to mount. I bought a scythe Kotetsu for my son a similar price that is probably better than either. https://www.newegg.com/Product/Product.aspx?Item=9SIA9ZH3S91295&cm_re=scythe_kotetsu-_-13C-0004-00005-_-Product Here is a review: http://www.silentpcreview.com/Scythe_Kotetsu
geofelt Titan Oct 9, 2006 56,083 4,866 174,240 Jul 1, 2017 Solution #2 I5-6500 will come with an adequate stock cooler. It may get noisy under load though. Of your choices, I would pick the pure rock slim. Apparently the hyper212 is hard to mount. I bought a scythe Kotetsu for my son a similar price that is probably better than either. https://www.newegg.com/Product/Product.aspx?Item=9SIA9ZH3S91295&cm_re=scythe_kotetsu-_-13C-0004-00005-_-Product Here is a review: http://www.silentpcreview.com/Scythe_Kotetsu Upvote 1 Downvote Solution
F Facelessman Commendable Jan 9, 2017 41 0 1,530 Jul 5, 2017 #3 Thanks and sorry for the late answer Upvote 0 Downvote
