Question Hyper V Virtual machine cpu usage
Jul 15, 2025
4
So I'm trying to run multiple VMs running a game (10 game clients) each VM to bypass the ip limitations (can only run 10 game clients per ip). So to bypass this I was wanting to use a VM and VPN, Now before this limitation, I use to be able to run 70 game clients on my computer just without being on a VM. But them running on a VM on windows 11, I can get 10 game clients total on one singular VM. However the ram usage and cpu usage skyrockets to %50 Cpu just doing 10 game clients on just one VM. Is this just how it is?, or am I doing something wrong with optimization? Thanks
What CPU do you have? Does it have virtualization and did you turn it on in the bios?
The ram you have to divide yourself, in the VM settings only give it as much as it needs to run the 10 clients, having the OS running probably takes most of the ram though.
Just so we are all on the same page here...
With the exact same setup you have in place now you were running 70 virtual clients. Nothing else has changed aside from (presumably) Hyper V has placed a 10 client per IP limit in place?
Not one single other thing hardware or environment has changed in the meantime?
What are you working with and for?
So I'm trying to run multiple VMs running a game (10 clients) each to bypass the ip limitations (can only run 10 clients per ip). Before this limitation I use to be able to run 70 clients on my computer. But now with one VM on windows 11, I can get 10 clients but the ram usage and cpu usage skyrockets just doing 10. Is this just how it is?, or am I doing something wrong with optimization? Thanks
Give us full config details, before and after.
No no 10 game clients
Ive tested both my 13900hx with 4080 and my 5800x3D which i was running 70 game clients without them being on VM
