I am buying ripjaws x ddr3 1333mhz 8gb. After 2months m going to buy another same ram. So will this both work together or will
Omi008
Please help. Can i know will they both work together or give blue screen error or game installation failure ?
Or any other 8gb ddr3 1333mhz ram that that can work with gskill ripjaws x 8gb ddr3 1333mhz ram.
No, it's a crapshoot, they might play, might not, if you try and have problems, give me a shout and we can try voltage/timing adjustments 😉
Maybe - no guarantees when mixing sets of DRAM even of the same exact set - I've gotten matching sets direct from the manufacturers before that didn't want to play - sometimes you can get them to play but not alsways, Had a 2 pairs of 2 two stick sets from two manufacturers for my article here:
http://www.tomshardware.com/reviews/dram-benchmark-fluctuations,4080.html
that I was able to get to play fairly easily, but have had others that just wouldn't play
But is there 100% chance of not working??
