G Gaurav_22 Commendable May 21, 2016 1 0 1,510 May 21, 2016 #1 its window 7 dual core pc problem in inatsalling VGA
Solution Colif May 22, 2016 can you put more of the topic into the message? so you swapped graphics cards? did you remove the old drivers? if not, try this: http://www.tomshardware.com/faq/id-2767677/clean-graphics-driver-install-windows.html
Colif Win 11 Master Moderator Jun 12, 2015 65,272 6,473 168,090 May 22, 2016 Solution #2 can you put more of the topic into the message? so you swapped graphics cards? did you remove the old drivers? if not, try this: http://www.tomshardware.com/faq/id-2767677/clean-graphics-driver-install-windows.html Upvote 0 Downvote Solution
