I am in pakistan and I am looking for the best pc build with perpherals for around Rs.180000 to 200000
pakistanmz
7
I need the pc for gaming mainly.a future proof one since i do not plan on upgrading.Also as power efficient as possible.I am not being able to decide and dont wanna make any mistakes in my first gaking build.Any help will be appreciated.thank you
This build assumes you won't get a second GPU down the road, but you can overclock. I also low balled the price converted from USD because I don't know where to build online with your country's currency.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($229.97 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($99.99 @ Amazon)
Motherboard: Asus Z87-K ATX LGA1150 Motherboard ($101.99 @ NCIX US)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($82.05 @ NCIX US)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk ($89.99 @ Adorama)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.67 @ Amazon)
Video Card: EVGA GeForce GTX 780 Ti 3GB Video Card ($709.99 @ Newegg)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case ($109.99 @ NCIX US)
Power Supply: EVGA SuperNOVA 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($74.99 @ Microcenter)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 - OEM (64-bit) ($94.98 @ OutletPC)
Total: $1673.59
(Generated by PCPartPicker 2014-01-23 15:45 EST-0500)
CPU: http://www.czone.com.pk/processors-intel-core-i7-processors-intel-core-i7-4770k-processor-4th-generation-haswell-pakistan-p.1855.aspx,
GPU: http://www.czone.com.pk/graphic-cards-nvidia-geforce-gigabyte-gv-n78toc-3gd-geforce-gtx-780-ti-3gb-384-bit-gddr5-pci-express-3.0-hdcp-ready-video-card-pakistan-p.2473.aspx
Some relatively less powerful GPUs but much better price: http://homeshopping.pk/categories/Graphics-Card-in-Pakistan/?sort=priceasc
Motherboard: http://www.czone.com.pk/motherboards-lga-1150-socket-asus-maximus-vi-hero-lga-1150-intel-z87-hdmi-sata-6gb-s-usb-3.0-atx-intel-motherboard-pakistan-p.1955.aspx
Storage: http://www.czone.com.pk/hard-drives-desktop-sata-hard-drives-seagate-st1000dx001-1tb-7200-rpm-64mb-cache-sata-6.0gb-s-ncq-3.5-desktop-solid-state-hybrid-drive-pakistan-p.2098.aspx
Case: http://www.czone.com.pk/casing-thermaltake-thermaltake-chaser-a31-chassis-pakistan-p.1897.aspx
Power Supply: http://galaxy.com.pk/corsair-gaming-series-gs-600w.html
RAM: http://www.czone.com.pk/memory-module-ram-desktop-ddr3-memory-corsair-vengeance-16gb-2-x-8gb-240-pin-ddr3-sdram-ddr3-1866-desktop-memory-model-cmz16gx3m2a1866c10-pakistan-p.2645.aspx
Case Fan: if needed. any should be fine - http://www.czone.com.pk/cooling-solutions-case-fans-pakistan-pt.174.aspx
Buy front first then top then bottom (if not buying all at once)
CPU Cooler: Buy when u decide to overclock
SSDs are way too expensive here, best to skip them for now unless of course u want to stretch your budget
Hope this helps
In which city are u?
I am also in pakistan and i think i am going to tell you a good pc
buy it from your nearest store
CPU:3.0 ghz core i5 Quad core processor
Ram:8 gb ddr3 1600mhz
GPU:nvidia geforce gtx 780
M board : Asus Z87-K
CASE : rosewill dual fan case
Psu : 600 watts
wter cooling is important
and buy a 1 tb hdd instead of a ssd or 2 tb hdd
Specops, the Build u made a list of is much more high in Cost..
i7 4790k
16 gb ddr3 2133 or 2400.
1 tb, 128 ssd
970 4gb
cooling, case, dvd, 750 psu and any Good mobo like gaming 7 gigabyte will cost max 12 to 1300.. if u buy the parts Online then the cost will be high. if online but from PC BUILDERS website then okey from local shop.
i build a pc without GPU i7 6700 skylake with ddr 4 for 1200$..
