I am looking for a good motherboard for my pc HELP!!!
Alexapo13
20
pc specs:
cpu:amd fx6300
gpu:gtx 760
ram:2 of 4gb 1600mhz
case:corsair 300r
At first i thought about the asus m5a99fx pro but i have a bugdet around 800 dollars and i am searching for a motherboard where i could upgrade in the future with a better cpu or a better graphics card and i would like to be able to overclock my fx6300.
obviously that's why i posted it , yes you will :)
1) You can use the asus 970 chipset MB for the fx6300, but you have problem to use the FX9 series CPU.
2) The cheaper 990 chipset MB can oc the fx6300 but it is not good for newer FX 9 series cpu too. If you need use the FX9 series you need the MB has at least 8+2 power phase count. But for FX8 series, the asus m5a99fx pro is good enough.
