Question I am planning a semi-budget computer for CAD (Solid Works software) and would like to know if I am going to need extra cooling
Mar 7, 2019
8
Hi and thanks in advance. Some of the parts:
GPU: Nvidia Quadro P620 https://www.techpowerup.com/gpu-specs/quadro-p620.c3085
CPU: Intel Core i5-8600K Coffee Lake 3.6GHz
https://www.intel.com/content/www/us/en/products/processors/core/core-vpro/i5-8600k.html
x2 16GB DD4 Ram, 1T SSD hard drive
Case: Fractal Design Focus G ATX Mid Tower Computer Case (Notice the double fan)
https://www.vuugo.com/fractal-design-pc-cases-FD-CA-FOCUS-BK-W.html?tracking=5108053939762
PSU: Corsair CX-M Series CX550M 550 Watt 80 PLUS Bronze Certified Power Supply (semi-modular)
https://www.canadacomputers.com/product_info.php?cPath=33_1238_442&item_id=096572
I am not sure how to calculate temperature needs so any help would be greatly appreciated.
The GPU is only 40 watts maximum, so the two front fans are probably enough, but I would add a rear exhaust fan or move one of the front fans to the rear. Your Intel CPU does not come with a heatsink/cooler so you will need to add one or choose a non-K CPU which will come with a heatsink. If you have not been here, you may find it helpful:
https://www.pugetsystems.com/recomm...s-for-SOLIDWORKS-150/Hardware-Recommendations
