I have a 144Hz monitor and I bought an HDMI-DVI Adapter and my monitor won't go to 144Hz!
don8 pl0x
28
I don't know why, even when I bought a $35 HDMI to DVI adapter, my monitor still refuses to go to 144Hz. I don't know why and it's making me very upset, as I bought this monitor just for the 144Hz.
Well, it looks like your laptop does not have a DVI-D duel link port, and I highly doubt that this computer has the processing power to display 144hz, let alone 120hz. Your best bet to just use an HDMI to HDMI connection to display 60hz, until you buy either a desktop, or another computer with the power to display 144hz.
HDMI to DVI adapters won't support that refresh rate. You must have an HDMI to HDMI connection to have at least 120hz. DVI and VGA don't support 144hz. In order to achieve 144hz, you must have a display port to display port connection.
Here's a good link for you: http://www.144hzmonitors.com/knowledge-base/144hz-1080p-which-cable-do-i-need/. The issues to look at are:
1. Are you using an HDMI cable that is version 1.3 or higher?
2. What GPU are you using? Does it support HDMI 1.3 or higher.
Of course, the best solution is to use displayport if you can.
To my knowledge, if it is DVI-D, then yes. You must have a DVI-D to DVI-D connection to the monitor. Adapters such as DVI to HDMI will limit the bandwidth on the cable, prohibiting the 144hz functionality. Also HDMI 1.4 does support 120hz at 1080p, but Display port and DVI-D support 144hz.
How do I know which version of HDMI the cable is?
Also the cable and the computer are dvi-d. My monitor is dual link, but I'm not sure if the cable is.
Edit: Looked at the box and it supports dual link and many other types of dvi. Does that mean they are both DVI-D dual link?
If your DVI cables look something like this https://www.amazon.com/C2G-DVI-D-Dual-Link-Cable/dp/B0000X0VCY then you have DVI-D duel link. I should of mentioned that it has to be duel link to provide the 144hz, not single link. Single link looks like this, https://www.amazon.com/StarTech-10-Feet-Single-Digital-Monitor/dp/B0000BZNTE/ref=sr_1_1?ie=UTF8&qid=1483210812&sr=8-1&keywords=dvi+d+single+link. Also what model laptop you have?
