Hi guys,
I am putting together a new system, have decided to get the z97 pc mate Mobo and the Intel Pentium G3258 processor I do not want to overclock.
I already have a Kingston hyperx fury 4GB 1866mhz speed RAM module black series. Code number for that is HX318C10FB/4. I am slightly confused as to whether it will be supported by Intel G3258 without overclocking.
Since the mobo (msi z97 pc mate) supports 1866 only at over clocking, do I need to overclock just to make the G3258 run at 1866mhz speed, or will the 1866 speed hyperx fury RAM that I have will downgrade itself automatically " in case of no overclocking " to 1333 speed of the processor and the mobo ?
Basically, will it work without overclocking ? Without a problem ?
Alternatively, should I just get a new ram stick of 4 GB 1600 speed c9 latency and buy the i3 4150 and the msi b85-G43 motherboard ? The price here will be around the same for both the combinations.
I don't wanna overclock as of now. May be never.
I'm in a dilemma. I would appreciate your effort and time in this problem. Thank you in advance good fellows,
S.
S.
