I have a problem with my computer crashing with i play games
Modman83
Here are my specs:
MSI 990FX-GD65
AMD fX-8350 4ghz
Kraken x60
32gb 1866mhz ram
Diablotek RPM series RPM900 900W ATX Power Supply
wd 1gb hard drive
Windows 7
Great GPU, so the PS is most likely the culprit! All your other stuff is pretty good, so you ought to get a decent Corsair or Seasonic PS and it will probably work extremely well!
Assuming that that your CPU and/or GPU is not overheating and/or inappropriately OC'ed there is only one part in your list that is likely causing problems, your power supply! A bad power supply is the single component most likely to cause problems with a performance computer. Check out this list, your PS is in Tier 5, not good!
http://www.eggxpert.com/forums/thread/323050.aspx
The rest is fine although you didn't mention your GPU. If it is simply to low on the GPU totem pole, so to speak, then that could also be a problem!
ok the gpu is MSI R7950 Twin Frozr 3GD5
ok thanks
