I have an AMD Sapphire 7770 GPU and an Intel Core i5. Would I be able to run dayz for decent frame rates on low-medium setting
Crusty88
4
I have an AMD Sapphire 7770 HD GPU and an Intel Core i5. Would I be able to run dayz for decent frame rates on low-medium setting?
I don't know about those reqs because I have heard that DayZ can be hard to run even on higher end systems.
Well the game hasnt been optimized yet. So yes, some high end pcs may not have perform as well for DayZ. But you do meet the requirements and I do think you will be okay.
Just turn the settings down. A mix of low-med settings possibly at 1080p. Never had that specific card so my experience is low with it. The 7770 is still a very budget card and you might want to consider an upgrade if you start playing more demanding games. Your cpu is fine considering it is an i5, so no upgrade is needed there.
