I have an asus q200E-BSI3T08 laptop. It does power up but does not charge
Kadiasks
I have an asus q200E-BSI3T08 laptop. It does power up but does not charge, now that the battery is dead, it can't power up. note that the batter isn't detachable like most laptops. When I plug in the charge, it makes a slight spark but that's it, the red light thats supposed to turn on when you plug it in the charger stays off, meaning it's not charging. I took it to two repair shops and they cant figure it out so I want to fix it myself. Problem is, I don't know what to fix. LOL.. any suggestions?
Two things you can try, first off plug your charger into the laptop and try wiggling it. If it moves excessively, the charge port might be loose inside. Will probably need to get that re-seated. Otherwise, have you tried replacing the charger?
yeah, I replaced the charger, and the charging port is fine. I have tested it. and had others test it two, they both say it's the charging circuit of the motherboard that's causing the problem. The question is. How can I fix the charging circuit?
