M mommy_0607 May 16, 2018 1 0 10 May 16, 2018 #1 I have an RCA flat screen with built in DVD and the aound will not work what could be wrong or how do I fix it
Solution A A Alabalcho May 17, 2018 Check the volume. Check that there are no headphones connected. If there's a way to reset it (check the manual), do it. If you have no electronic skills, there's little you can do but check with RCA repair center.
A Alabalcho Titan Jan 13, 2011 14,016 432 81,090 May 17, 2018 Solution #2 Check the volume. Check that there are no headphones connected. If there's a way to reset it (check the manual), do it. If you have no electronic skills, there's little you can do but check with RCA repair center. Upvote 0 Downvote Solution
