I have resolution problem.
Feb 12, 2014
29
Recently I have installed Windows 7 64-bit on my PC. It has internal Video Card and I have installed drivers and working perfect and now I have problem with setting resolution on my LCD monitor.
The current resolution is 1280 x 1024 in which width the fit and height is not fit. I have option to manually add its resolution so if I should then what resolution I add in settings.
You can try entering the below resolutions.
1366 X 768
1600 X 900
1960 X 1080
Try the minimum one to see whether it works. Then try the next and onward. Set the maximum your monitor can handle.
I suppose what you have is an 17" / 19" LCD monitor with 4:3 Ratio. Actually your resolutions are fine since you have all the drivers installed.
Go to monitor menu by accessing buttons on your monitor.
If it has an auto adjust key, just press it. if it didn't solve,
There you'll see settings to widen the height. Then you can use "Move" to center it. After that press auto adjust to align the pixels.
This is my LCD. I have checked its settings but there is no option to make changes in width or height.
I have tried Auto Adjustments option but didn't work and vertical/horizontal adjustments option isn't available.
P.S. before this problem, I had external Graphic Card where everything was working fine and now when I have removed it and using internal then this problem is occurring. What you think, is this problem occurring because of internal Graphic card?
