I have sound from both headphones and speakers
Giorgos
26
I have a laptop. When i open it in playback devices i have only the speakers. When i plug my headphones i hear everything from there with the playback devices only being the speakers. But, when i open certain programs like mumble a second playback device appears called Communications Headphones (IDT high definition audio CODEC). It doesnt matter if i have my headphones plugged. Then from the same program some sounds come out of the speakers and others from the headphones. How can i make everything to come out of my headphones or just make this second playback device disappear?
Edit. I disabled and everything is fine now. Sorry for the bother.
oxycontiin
25
Just to post an answer for this for anyone else reading, I believe Win 7 can run multiple sound outputs at once. So if you have your headphones on and then throw in your optical output you could end up with audio being sent to both headphones and speakers. If you right click and get the properties up, you can fiddle around with the controls and tell it what you want as your default audio output. If you have multiple of those little speaker symbols on the taskbar you could mute all the ones you don't want if you're lazy, but the proper way to only use what you want would be to head back over to properties, pull up the list of all audio devices, right click and disable what you don't want.
You said you figured it out. I assume your solution was something similar?
Similar threads
