Question I installed my 9070xt and my monitor said I had no signal. Is my GPU faulty?
I tried installing my GPU(9070 xt pulse) today from a 2070 super. I did uninstall my previous gpu drivers. But when i booted it up nothing was showing up on my display. I checked to see if I plugged in the pcie wrong several times but I still got the same results.
I put my old GPU back in and it's powering on just fine. So I am wondering if this is because my 9070 xt is bad or an issue with my power supply.
Pc specs:
Ryzen 5700x3d CPU
Asus tuf x570 plus Mobo
Seasonic FOCUS GM-750 PSU
As someone who recently messed up a GPU install, check the PSU cables to the GPU, i connected them enough to get the card to turn on without getting a picture, check the conectors and make sure they click in.
What BIOS version are you on for your motherboard?
How old is the PSU in your build?
Have you tried dropping the RX 9070 XT into the lower PCIe x16 slot?
I have the latest bios version and my PSU is 5 years old. I don't think i have the space to plug it in bottom pcie.
Pc specs:
Ryzen 5700x3d CPU
make sure you are running 2 pci cables. 1 8 pin cable even if it has another connector only does 150w. you will need to use 2 seperate gpu power cables as these cards get direct power from the power supply on start up not the pci slot.
Latest posts
