Nope. There was only one "real" test done to check WD vs. Seagate and it was found to be flawed in basically every way and discredited. I use Seagate drives in all my machines with no problems.
Funny enough, the only drive I have ever had fail was a WD.
Add whatever cooler you want and storage, get WD Red or something. Any other advice from the experts here is appreciated, I am not that good but these seem like nice choices.
Quite aware of it. I was just indulging the OP since he really doesn't mind spending the money. It is definitely a waste of money but the best-in-class items.
@OP
If you can tell us exactly what you're going to use your computer from most important to least important, we can help you better.
What programs will you be using for rendering and programming? You DO NOT need a 1000 dollar i7. A normal x99 CPU will be plenty and even a Z97 i7 would be too.
Lots of gaming, running it 24/7, rendering, computer programming, Netflix, internet, downloading movies, game recording,
the build i suggested will give you the best performance BUT as tiny voices pointed out, it is also a waste of lots of money. I'll build you something more reasonable. Give me a bit.
