[SOLVED] I need a case for a Mini ITX, console killer-like build
IDProG
I am planning to upgrade my PC build in Q4 and I am planning the build to be a console-killer style build.
However, I am experiencing difficulties in choosing a Mini ITX case for my build.
My PC's purpose is to play games.
Any case is fair game, as long as it abides to the conditions.
So, here are my conditions.
The case MUST (must follow these conditions):
1. Cost $150 or less
2. Be a Mini ITX case
3. Not be one of these:
All Lian-Li cases
NCase cases
Sentry case
Other cases (I will update this list if you suggest a case that isn't available in my country)
4. Not be too big (like Phanteks Evolv ITX, NZXT H210, NZXT Manta, Silverstone GD08, etc.)
Bonus points (optional) if the case:
1. Has enough clearance for AMD Wraith Stealth CPU Cooler
2. Supports an ATX PSU
3. Has (at least) one 3.5" Drive Bay
4. Has a form factor of one of these:
Console-like (like Fractal Design Node 202)
Small Cube (like Silverstone SG13)
5. Costs $100 or less
6. Can fit a reference GPU (10.5") or longer
Thank you for reading this thread. Any help is appreciated.
InWin A1 Plus
Fractal Node 202 (as mentioned)
Cougar QBX
Skyreach 4 Mini
I guess no case in that size category will fit an atx powersupply. Apart from the NCase that you dont want for some reason.
IDProG
Unfortunately, Silverstone ML03 is not available in my country.
Silverstone GD09 is too big for my taste.
Fractal Design Node 304 looks awesome. I'll consider that.
Thank you for the suggestions. I appreciate it.
IDProG
InWin A1 Plus
Cougar QBX
Skyreach 4 Mini
Unfortunately, Skyreach 4 Mini isn't available in my country.
InWin A1 Plus costs more than $150, but I'm going to make a special exception for it because it comes with a PSU.
I like the 3 cases that you recommended. I'll consider those.
Thank you for your suggestions. I appreciate it.
