I need a CPU that will work with this MB...
d3lit3
103
Ok so I wanna upgrade my CPU but I don't want to buy a new motherboard because I don't have enough money. Right now I have a Pentium D @ 3.9 Ghz and I want to upgrade to a CPU that's compatible with my motherboard which is a;
GIGABYTE GA-8I945P-G-RH
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1960
So will any relatively new CPU work with my motherboard? Doesn't matter if it's AMD or Intel.
Thanks.
Here's a few suggestions:
Intel Core™ 2 Extreme QX9770(3.2GHz,12 MB) 1600 N/A
Intel Core™ 2 Extreme QX9650(3.0GHz,12MB) 1333 N/A
Intel Core™ 2 Quad Q9550(2.83GHz,12MB) 1333 N/A
Intel Core™ 2 Quad Q9450(2.66GHz,12MB) 1333 N/A
Intel Core™ 2 Quad Q9300(2.50GHz,6MB) 1333 N/A
Intel Core™ 2 Duo E8500(3.16GHz,6MB) 1333 N/A
Intel Core™ 2 Duo E8400(3GHz,6MB) 1333 N/A
Intel Core™ 2 Duo E8300(2.83GHz,6MB) 1333 N/A
Intel Core™ 2 Duo E8200(2.66GHz,6MB) 1333 N/A
Intel Core™ 2 Duo E8190(2.66GHz,6MB) 1333 N/A
Intel Core™ 2 Extreme QX6850(3.0GHz,8MB) 1333 N/A
Intel Core™ 2 Extreme QX6800(2.93GHz,8MB) 1066 N/A
Intel Core™ 2 Extreme QX6700(2.66GHz,8MB) 1066 N/A
Intel Core™ 2 Quad Q6700(2.66MHz,8MB) 1066 N/A
Intel Core™ 2 Quad Q6600(2.4GHz,8MB) 1066 N/A
Intel Core™ 2 Extreme X6800(2.93GHz,4MB) 1066 N/A
Intel Core™ 2 Duo E7300(2.66GHz,3MB) 1066 -
Intel Core™ 2 Duo E7200(2.53GHz,3MB) 1066 N/A
Intel Core™ 2 Duo E6850(3.0GHz,4MB) 1333 N/A
Intel Core™ 2 Duo E6750(2.66GHz,4MB) 1333 N/A
Intel Core™ 2 Duo E6550(2.33GHz,4MB) 1333 N/A
Intel Core™ 2 Duo E6540(2.33GHz,4MB) 1333 N/A
Intel Core™ 2 Duo E6700(2.66GHz,4MB) 1066 N/A
Intel Core™ 2 Duo E6600(2.4GHz,4MB) 1066 N/A
Intel Core™ 2 Duo E6420(2.13GHz,4MB) 1066 N/A
Intel Core™ 2 Duo E6400(2.13GHz,2MB) 1066 N/A
Intel Core™ 2 Duo E6320(1.86GHz,4MB) 1066 N/A
Intel Core™ 2 Duo E6300(1.86GHz,2MB) 1066 N/A
Intel Core™ 2 Duo E4700(2.60GHz,2MB) 800 N/A
Intel Core™ 2 Duo E4600(2.40GHz,2MB) 800 N/A
Intel Core™ 2 Duo E4500(2.2GHz,2MB) 800 N/A
Intel Core™ 2 Duo E4400(2.0GHz,2MB) 800 N/A
Intel Core™ 2 Duo E4300(1.8GHz,2MB) 800 N/A
Intel Pentium Dual-Core E2220(2.40GHz,1MB) 800 N/A
Intel Pentium Dual-Core E2200(2.2GHz,1MB) 800 N/A
Intel Pentium Dual-Core E2180(2.00GHz,1MB) 800 N/A
Intel Pentium Dual-Core E2160(1.8GHz,1MB) 800 N/A
Intel Pentium Dual-Core E2140(1.6GHz,1MB) 800 N/A
Intel Celeron Dual-Core E1400(2.0GHz,512KB) 800 -
Intel Celeron Dual-Core E1200(1.60GHz,512KB) 800 N/A
Intel Pentium-Extreme Edition 965(3.73GHz,4MB) 1066 N/A
Intel Pentium-Extreme Edition 955(3.46GHz,4MB) 1066 N/A
Intel Pentium-Extreme Edition 840-XE(3.2GHz,2MB) 800 N/A
Intel Pentium D 960(3.6GHz,4MB) 800 F3
Intel Pentium D 950(3.4GHz,4MB) 800 F2
Intel Pentium D 945(3.4GHz,4MB) 800 F3
Intel Pentium D 940(3.2GHz,4MB) 800 F2
Intel Pentium D 935(3.2GHz,4MB) 800 F2
Intel Pentium D 930(3.0GHz,4MB) 800 F2
Intel Pentium D 925(3.0GHz,4MB) 800 F3
Intel Pentium D 920(2.8GHz,4MB) 800 F2
Intel Pentium D 915(2.8GHz,4MB) 800 F3
Intel P4-Extreme Edition 3.73GHz(2MB) 1066 F2
Intel P4-Extreme Edition 3.46GHz(2MB) 1066 F2
Intel P4-Extreme Edition 3.4GHz(2MB) 800 F2
Intel Pentium D 840(3.2GHz,2MB) 800 F2
Intel Pentium D 830(3.0GHz,2MB) 800 F2
Intel Pentium D 820(2.8GHz,2MB) 800 F2
Intel Pentium D 805(2.66GHz,2MB) 533 F2
Intel Pentium 4 672(3.8GHz,2MB) 800 F2
Intel Pentium 4 670(3.8GHz,2MB) 800 F2
Intel Pentium 4 662(3.6GHz,2MB) 800 F2
Intel Pentium 4 661(3.6GHz,2MB) 800 F2
Intel Pentium 4 660(3.6GHz,2MB) 800 F2
Intel Pentium 4 651(3.4GHz,2MB) 800 F2
Intel Pentium 4 650(3.4GHz,2MB) 800 F2
Intel Pentium 4 641(3.2GHz,2MB) 800 F2
Intel Pentium 4 640(3.2GHz,2MB) 800 F2
Intel Pentium 4 631(3.0GHz,2MB) 800 F2
Intel Pentium 4 630(3.0GHz,2MB) 800 F2
Intel Pentium 4 571(3.8GHz,1MB) 800 F2
Intel Pentium 4 570J(3.8GHz,1MB) 800 F2
Intel Pentium 4 561(3.6GHz,1MB) 800 F2
Intel Pentium 4 560(J)(3.6GHz,1MB) 800 F2
Intel Pentium 4 551(3.4GHz,1MB) 800 F2
Intel Pentium 4 550(J)(3.4GHz,1MB) 800 F2
Intel Pentium 4 541(3.2GHz,1MB) 800 F2
Intel Pentium 4 540(J)(3.2GHz,1MB) 800 F1
Intel Pentium 4 531(3.0GHz,1MB) 800 F1
Intel Pentium 4 530(J)(3.0GHz,1MB) 800 F2
Intel Pentium 4 524(3.06GHz,1MB) 533 F3
Intel Pentium 4 521(2.8GHz,1MB) 800 F2
Intel Pentium 4 520(J)(2.8GHz,1MB) 800 F1
Intel Pentium 4 519K(3.06GHz,1MB) 533 F2
Intel Pentium 4 516(2.93GHz,1MB) 533 F2
Intel Pentium 4 515(J)(2.93GHz,1MB) 533 F2
Intel Pentium 4 511(2.8GHz,1MB) 533 F1
Intel Pentium 4 510(J)(2.8GHz,1MB) 533 F1
Intel Pentium 4 506(2.66GHz,1MB) 533 F2
Intel Pentium 4 505(J)(2.66GHz,1MB) 533 F2
Intel Celeron 400 Sequence (Conroe-L) 440(2.0GHz,512KB) 800 N/A
Intel Celeron 400 Sequence (Conroe-L) 430(1.8GHz,512KB) 800 N/A
Intel Celeron 400 Sequence (Conroe-L) 420(1.6GHz,512KB) 800 N/A
Intel Celeron D 360(3.46GHz,512KB) 533 F4
Intel Celeron D 356(3.33GHz,512KB) 533 F3
Intel Celeron D 355(3.33GHz,256KB) 533 F2
Intel Celeron D 352(3.2GHz,512KB) 533 F3
Intel Celeron D 351(3.2GHz,256KB) 533 F2
Intel Celeron D 347(3.06GHz,512KB) 533 F3
Intel Celeron D 346(3.06GHz,256KB) 533 F1
Intel Celeron D 345J(3.06GHz,256KB) 533 F2
Intel Celeron D 341(2.93GHz,256KB) 533 F1
Intel Celeron D 340J(2.93GHz,256KB) 533 F2
Intel Celeron D 336(2.8GHz,256KB) 533 F2
Intel Celeron D 335J(2.8GHz,256KB) 533 F2
Intel Celeron D 331(2.66GHz,256KB) 533 F2
Intel Celeron D 330J(2.66GHz,256KB) 533 F2
Intel Celeron D 326(2.53GHz,256KB) 533 F1
Intel Celeron D 325J(2.53GHz,256KB) 533 F1
it doz matter if its amd or intel coz amd wont work in it....lol
i dont think c2d is supported by this 945 chipset.some 945 supports c2d, but if it does, it should say so on the retail box
If you read the compatibility chart all the core2duo's have N/A behind them which means that they don't WORK!
The header for that support list is clear about it.
"CPU Support List
Fx = Since BIOS Version OK = Test OK! N/A = Not support "-" = Under Testing"
MrsBytch is right ..... you put a link to the mobo info yet you can't even click the cpu support list and find out for yourself. That is not a good way to get respect in these forums.
Anyways you'll probably get banned for the type of language you used so we won't have to put up with your laziness for too long !
LMAO 2 this Dw3tl3 w3abl3 Dweetle weable. LOL
Come on people, why wouldn't he click it if he saw it? We're all human and if people are simply going to get flamed then thier less likely to come into forums which means we have less computer savvy people in the world, which is exactly what people are complaining about. Peace ya'all.
