I've been looking at various custom PC builders like Velocity Micro, Alienware and Dell, and I think it would be cheaper to build a system myself. From different configurations I've seen I think I'm leaning toward
• Processor Intel® Core™ 2 Extreme processor QX6700, quad 2.66GHz cores, 8MB L2 Cache
• ASUS Striker Extreme Socket T (LGA 775) NVIDIA nForce 680i SLI ATX Motherboard or similar board.
• ENERMAX GALAXY EGA1000EWL ATX/BTX 1000W Power Supply 100
• DDR2 Memory 4096MB Corsair Dominator DDR2-1066 Twin2X2048-8500C5D* Dual-path Heat Xchange
• 2 x BFG Tech GeForce 8800 GTX 768MB Water Cooled PCI Express graphics card in SLI DDR3 PCI-Express
• Multimedia TV Tuners ATI Theater™ 650 PRO or ATI TV Wonder 650
ATI Technologies TV Wonder 650 PCI NTSC [/b]
• Physics Processor 128mb Asus® AGEIA™ PhysX™ Processor Ghost Recon Edition
• Areca ARC-1210 4 ports 500 MHz PCI-Express to SATA-II RAID 6 Adapter, Areca Premium 256M SoDimm ECC-Raid Controller card.
• 4 x 150GB Western Digital Raptor 10,000rpm SATA/150, 16MB Cache, NCQ -RAID 0 Stripe (600GB Total)
• Sound Blaster® X-Fi™ XtremeGamer Fatal1ty Professional Series sound card , 64MB X-RAM for high performance and superior digital audio
• Floppy Drive & Media Reader 8-in-1 Floppy Drive & Media Reader Combo
• Bigfoot Networks Killer NIC M1 10/100/1000Mbps PCI Network Adapter with a 400 MHz Network Processing Unit (NPU) 1 x RJ-45, 1 x USB2.0
• Microsoft® Windows® Vista Home Premium Edition
First, the Striker Extreme only has 6 expansion slots (
3x PCIe x16 - 2 used by your 8800GTX's, 1 used by the Areca RAID card;
1x PCIe x1 - not used;
2x PCI - 4 used by your X-Fi, KillerNIC, PhysX card and TV Tuner card) meaning that you have 2 too many PCI devices. The slot above your video card is only usable by the ASUS SupremeFX audio card.
Second, you do realize that you will require a water-cooling setup in the machine to take advantage of the single-slot GeForce 8800GTX's, right? If you don't implement a water-cooling setup for them, they will fry. If you're not going to use water cooling, then you will need the standard BFG 8800GTX's which are dual-slot, and will lose 2 slots (one PCI, one PCIe x1).
Third, if you are going to spend ~$1500+ on a RAID setup, make it RAID 5. Otherwise you are wasting the ~$500+ RAID controller card using it for a RAID 0. Better yet, use 2x 150GB Raptors in RAID-0 for system on the nVidia controller, then use the Areca for a 4-drive RAID-5 of Seagate Barracuda 7200.10's of 320GB+ capacity.
Fourth, rather than dropping $250+ on a "Killer NIC", I would suggest looking at some of the Intel Pro/1000 Server network cards, as you can probably find one for cheaper with better support (and likely better optimized TCP/IP offload functionality).
Fifth, wait on the PhysX... until you get about 6 months from now, you won't know what Physics technology is going to become mainstream (assuming it will even be one of the current ones ...). With the Ageia using the PhysX implementation, and ATI and nVidia both buying into the Havok implementation via a tertiary video card running on a x8 lane, it's not worth $250+ without knowing if it will actually be of much use long-term.
Sixth, you won't actually be able to get Vista until Jan. 30/2007, so you may want to purchase a copy of XP MCE/XP Pro with an "Express Upgrade" coupon to assist in your migration to Vista.
Just my $0.02.
Thanks, you've been more help than most.
I'm well aware of water cooling.
My set up now is:GIGABYTE "GA-8IK1100" i875P
Swiftech Extreme Duty all-copper MCX159-CU chipset heatsink on the
Northbridge, plus Microcool Silver SouthSink & both Microcool ChipSink
Cooling Kit and microsinks
Intel Prescott 3.2E
Aquagate Water cooling System
OCZ 4GB (4 x 1GB) PC 3200 Dual Channel Platinum System Memory
Supertalent memory cooler
HIS Excalibur ATI Radeon X850XT IceQ II Turbo VIVO 256MB AGP
Maxtor 200GB 7200RPM SATA Hard Drive with 8MB Cache
Seagate 200GB 7200RPM SATA Hard Drive with 8MB Cache
CREATIVE Sound Blaster Audigy2 ZS
StarTech PCISATA2U5 - Storage / USB2.0 controller - SATA-150 - 150
MSI SATA 52x CDRW/DVD
Benq 1655 DVD-RW with Lightscribe
Logisys FP206BK Black 3.5 Inch LCD Thermal Controller (to monitor Hard
drives)
VANTEC NXP-305-BK Black Fan & Light Controller Panel
Koutech SOHOUSB IO-FPM220 3.5" Floppy Drive & Multi Card Reader Front Panel
Epower Jaguar 450W PSU
Windows XP Pro w/sp2
Dell 1800fp UltraSharp 18" LCD Flat Panel Display
Logitech cordless Laser Mouse
Logitech g-15 back lit gaming keyboard
SuperMax usb 56k modem
Wacom Graphire Digital Tablet & pen
Canon i9900 printer
Microtek v6usl Scanner
Canon Pro1 Digital Camera
and recently available AT&T DSL Pro. Elite isn't available yet.
I usually research a lot before I jump into something and this is research.
I've read reviews that the Killer NIC card isn't worth the expense now but I hoped it's price would drop when I was ready to add it to a system.
The PhysX card? most high-end PC builders include it as an option, and reviews I've read have been promising. I read that the G80 would handle PhysX but then why is it still a build option if it's a redundant technology? I know the obvious answer would be money, but I wish someone like THG would look into it and review it. The PhysX card is still a new idea but if your building a system that will cost several grand then it should still be an option.
As for the Raid card. The December issue of CPU Computer Power User has an article on hardware raid.
"A Necessity Or Novelty?"
Hardware Raid vs Software raid, Regardless of the type of RAID Array they employed, "the Areca hardware controller dominated the ICH7R. In regard to RAID 0 performance, the hardware and software controllers were comparable in Random Access and Read performance and in the various PCMark05 tests, but the hardware controller more than doubled the performance of the ICH7R in the Burst Read and Write Average tests. In RAID 5 configuration, the deltas get even larger, especially in regard to average write performance in which the Areca card offered a 25 fold increase in performance." Also, Velocity Micro includes a raid card in their high end PC builds. So I think they agree.
As for cost? I found the card for a little over $300.00 on line.
I guess if I can wait till this time next year, I've read that PCI Express 2.0 will be equiped on motherboards by next summer, DDR 3 memory is due out next year and Intel on the 45nm in the second half of 2007.
