So call me picky and what not but I really like certain cases. My Fractal core 1000 doesn’t cut it anymore, it’s way too small.
Preferably I would like a case with the following:
A nice open side panel windows that is big and would be excelent if it’s tempered glass.
Front ports including USB 3.0 in the FRONT or TOP of the case, not on the side like my Core 1000.
Drive bays (SSD and HDD) My core 1000 has none, it’s sad. 🙁
Also I need some 5.25” bays to put in a dvd drive and also in the future to add a fan controller or RGB controller or something.
I also would like a case with a filtered front mesh panel because I think that cases that block the fans choke them out and reduce airflow (unless someone can convince me otherwise). Also all places filtered for easy cleaning.
Finally these are the 2 cases that I really like but with problems.
https://www.corsair.com/uk/en/search/?text=750D&type=all
This one might be too big for what I have though.
https://www.thermaltake.com/mobile/productinfo.aspx?id=C_00003218
I absolutely adore this case but I have no idea where I can buy it from in the UK!
Opinions much appreciated! I’ll be happy to give more information if needed.
