I need advice on what to improve with PC build.
Here is a similar build, cheaper case, better SSD even though its a bit smaller, better cooler, and better quality memory. Basically however its the same thing around the same price
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($344.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($43.49 @ OutletPC)
Motherboard: Gigabyte GA-Z170X-Gaming 3 ATX LGA1151 Motherboard ($138.88 @ OutletPC)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory ($83.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($89.89 @ OutletPC)
Storage: Seagate...
Rogue Leader
It's a trap!
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($67.08 @ Amazon)
Video Card: Asus GeForce GTX 1070 8GB Video Card ($409.99 @ SuperBiiz)
Case: Corsair SPEC-02 ATX Mid Tower Case ($59.99 @ B&H)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($90.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.88 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($89.00 @ B&H)
Total: $1435.16
Generated by PCPartPicker 2016-08-02 10:42 EDT-0400
SO to answer your question yes its about as good as you will get for $1500
rhobariii
22
A person on another forum advised me to get a 500W power supply instead and use the leftover money to get more RAM. Can anyone verify if this would be a good choice?
Rogue Leader
It's a trap!
You do not need more than 16gb of ram unless you are doing HEAVY video editing/3d desgin/etc. I would not waste the money you will see no performance benefit.
You definitely can drop the power supply wattage as long as you stay the same quality. For example the EVGA 550G2 or GS are the same quality, less wattage, and still plenty to run this system. If they told you to get something like the EVGA 500B that is bad advice, its very low quality.
Rogue Leader
It's a trap!
Its perfect except the cooler, no reason to use a low profile cooler like that with a normal case. It won't cool as well as a tower.
Either get the Cryorig H7 I recommended or if you like Noctua (I do) get the NH-U12S or NH-U14S if it fits.
