My system Components are :
1,000 Watts - Cooler Master Silent Pro 80 Plus Gold Power Supply
Graphics card - Amd raedon 7990 Powered by AMD
CPU - Amd fx 8350 4.0ghz
CPU cooler - Thermaltake frio ock edition
I dont mind purchasing extra fans. The 7990 Pushes heat out the back and sides. I just need to keep the systems temperature low Noise really is not an issue. I was thinking to put 2 120mm Exhaust on the top. 140 mm exhaust (included with case) in the rear. Two 120 Side intake fans and two 120 intake fans in the front. Maybe even another 120mm intake fan On the bottom of the case. I am really open to your suggestions but it would be nice if i could have some theory behind airflow as i this is my first build. Thank you very much
