Question I need case for my AIO
beauknowsdiddly
414
21
18,815
Hey everyone!
I have an iCUE H150i ELITE CAPELLIX XT and the thing is freakin' huge! I have a Corsair 4000D and it will not fit. Can you please recommend a really cool case this thing would fit in without going over a couple hundred bucks? Can't believe I'm going to build a PC around an AIO but I've done goofier things!
Thank you!
Well it looks like you're in luck since they're currently having a sale on the 5000D which is $130 and can be shipped free; enter your zip code to verify date of receipt.
https://www.bestbuy.com/site/corsai...r-pc-case-black/6453227.p?skuId=6453227&gQT=2
This AIO is the big one by the way. 420mm which is really more like 460. or 18 inches. Will that work?
Apparently not it says:
Radiator Support
Front: 360mm / 280mm Top: 360mm/ 280 mm Motherboard Tray: 360mm/ 240mm Rear: 120mm
Radiator Support
do you mean the 170i because the 150i is the 360 mm ??
Anything that fits the arctic freezer 3 420mm in will surely fit the corsair 420 ..
My Thermaltake tower 300 with vertical stand kit will fit the arctic freezer 3 420mm and that is a big boy ( 458 ( L ) x 130 (w) x 38 (h) mm )
page 204 of the members system gallery thread if you want to see pics !!
You are absolutely right! I bought this on ebay and it was advertized as the 150i but now I see that it's the 170i. Sorry about that everyone.
Hey everyone!
Thank you!
The Antec Flux Pro is good for large AIO. The top can be fully removed which will make easier to install the water cooler and fans.
